Old Jun 29, 2024 | 02:36 PM
zip439's Avatar
zip439
Default Re: New to the Chrysler crossfire [QUOTE=zip439;990621]
Originally Posted by Wyliecoyote
Thanks for the fast reply and since then I have been told that the belt driven water pump is out of line and also because it's supposed to be all on the same line having the thing replacing should sort out a couple of other things such as tapping sound on idle but then I get told that the ABS ring needs to be replaced as abs light is on, I am not a mechanic at all so with speedometer not working and spoiler up I am just a little bit concerned, she drives like a dream I swear and it's manual so if I have a fool up the back end of the car they're just a distant memory in a couple of seconds as it is a very quick car, I am just truly in a panic that there's more wrong than I thought and now the CD player won't load. Any pointers you could give me I couldn't even explain how grateful I would be and apologise for being so mechanically lacking in knowledge but I learn extremely fast. Please if you get a chance I hope you can read through my message. Respect.
Wyliecoyote, I hope you contact the UK Crossfire groups listed above. They will have info as to mechanics that can work reliably on your car. Can the water pump make noise, yes, but how do you know it is out of alignment? You can see the belt rotate as the engine idles in park with the hood up. Is that belt wobbling, or not running true. Just look at it. The tensioner pulley goes bad more often than any of the others the belt drives. Did the same person tell you the ABS "ring" needs to be replaced? Cause that is highly unlikely! As I mentioned in my first post each wheel has speed sensors ( they are the electronic pickup at each wheel) and they go bad. They pick up a signal as the reluctor ring which is solid and part of the wheel rotates as your car moves. Those solid reluctor rings do not go bad. Far more likely the speed sensor goes bad. So what ABS "ring" are we talking about?
These are all minor concerns, so get some good trust worthy input. Meet up with someone from a Crossfire group in the UK and/or go to a good Mercedes mechanic.
