Old Jul 8, 2024 | 08:03 PM
bossman4's Avatar
bossman4
Default Re: Forward facing subwoofers in roadster
I am assuming that you cut a hole in the carpet that matched the inner diameter of the fabricated mount and then drilled through the carpet for the mounting screws for the woofer speaker frame.
Then you mounted the speaker cover on top of the mounted speaker.
So, if additional maintenance behind the carpet is required, the midrange woofer needs to be removed before the carpet is pulled away from the back.
