Old Jul 10, 2024 | 11:18 PM
  #8340 (permalink)
M60A3Driver
What did I do to my XF today? Well, it seems I jinxed the radio, it died! Was cruising on a pretty smooth road, turned it on, it played a while, changed the station & was into a song, and when I tried to raise the volume it would not work. Continued driving trying a few buttons, absolutely nothing. After a minute or so, it shut off and seems to have flown to the big radio cemetery in the sky... No more NAV radio (and I hardly even used the radio/NAV either). When the weather cools down some and I feel like it, I'll pull the radio and check the fuse at the rear of the radio (I seem to remember one there before). Didn't act like a bum fuse though, that's why I am surrendering, based on the way it acted before it shut off.
There was a post on here that I saw and it worked for me.
I remember there are 2 fuses in the engine fuse box. Remove bot of them. Then disconnect the negative battery cable for 3 minutes. Then put the fuses back i and then connect then reconnect the negative cable. It should reset the radio.
If I can find the post, I'll put it here.
