Thread: Easy way?
Old Jul 25, 2024 | 03:39 PM
zip439's Avatar
zip439
Default Re: Easy way?
Originally Posted by ZERACER
What would cause a crossfire to run too rich? It has a strong gas smell when it backfires? Possible intake valve?
Disconnect the EVAP solenoid valve line coming from the rear of the car, put a little vacuum on it and see if you get gasoline. It is located on the drivers side forward of the ESP/BAS module.
You should only get vapor from the EVAP canister from that line; If you get gasoline, there is your problem.
