Old Jul 29, 2024 | 08:55 AM
zip439's Avatar
zip439
Default Re: No communication no crank
Originally Posted by Tuner32
I found my problem crossfire I just got in April I know long time for a pin point Diagnosis, it was a problem with the pins 19 green pins at ECU connector. I'm posting because I wanted to share with the community what started the problem, I'm a 52 year technician, I noticed the seal at the bottom of the windscreen was missing, my Crossfire is super Clean never set outside but has been driving in the rain a time or two,
. 80008 miles, in the boot I found the New seal it's installed, I've Replaced RCM with new put my rebuilt one in the rear of my Crossfire like you have taught me, I'll be carrying the spare, any way the connectors are cleaned and waiting on the ECU.
. WILL UPDATE YOU ON THE STATUS.
When the ecu is here and I start my Crossfire. IM EXCITED.
"Waiting on ECU" How have you sourced the ECU? Hopefully you went to Mercedes Speed shop or Needswings. Do you know you can not swap ECU from any other Crossfire without re-programing to match your VIN and SKREEM.
