tdkflorida
After reassembling the instrument panel and was able to start the car with no issue.
However, now the ignition cylinder will not turn with the key, and there is a constant beeping sound with a flashing red light on the center counsel.
This is similar to the sound when the key is inserted into the ignition.
The only way to stop the beeping sound is to remove Fuse #35.
Thanks for your feedback!
The key not turning sounds like the sticky key issue. The system now thinks that you left the key in the ignition and is trying to remind you to remove it.
Look on the fuse panel door located on the driver's side dashboard when you open the door.
Usually if someone does the fix they write that it was fixed and the date.
