Thread: Audio speakers
Old Aug 2, 2024 | 09:53 AM
Sapphire_Breeze's Avatar
Sapphire_Breeze
Default Re: Audio speakers
Originally Posted by UnderTheSouthernCross
Hi mate,
The factory tweeters in mine tested good but were so muted in output that they literally could not be heard at all when the other speakers were working. I suspect the originals might be ferro-fluid filled and this may have gone hard over time - who knows? I don't know why else they would have continuity but no effective output. The Daytons need to have some weatherstripping applied to their perimeter so the sit snug in the factory tweeter mounting holes.
The Daytons work perfectly well, sound good and they have plenty of output. I generally run the treble on zero, sometimes +1 on a CD that needs it. With the subs fixed the bass is usually on zero or -1, -2, -3 depending on the CD.
With the Sub surrounds repaired and new JL C1 Tweeter in place, I cut a layer of 3/8' of open cell foam and put in front of the 6 ohm tweeters as I felt like they were just a little too bright.. I'm now running about Flat on bass and treble setting both. I suspect your Dayton choice would have been another good replacement costing half as much as the JL C1, 3/4"
