Old Aug 2, 2024 | 02:57 PM
DTMenace's Avatar
DTMenace
Default Re: motor grinding noise
Originally Posted by James Brookner
I marked the pulleys and turn the car over, all pulleys were turned. Not sure where the noise coming form in motor. Been afraid to turn it over too much that I cause more problems. Was going to pull vales cover off to see if turning with crankshaft. Also was going to pull belt and check all pulleys seperate.
Thanks
James
James
Your signature doesn't include the town you're located in Kansas. As a result, the attached link below is a shop that is located in Kansas and works on Mercedes Benz cars. You may want to call them and discuss your issues with your Crossfire, since it's 80% Mercedes Benz. Hopefully the shop is within towing distance.
Good luck in your attempt to get your Crossfire back on the road.
Regards,
Dennis
DTMenace
Car Wizard Reveals How Fixing Cars for YouTube Stars Turned His Shop Into a Film Studio - autoevolution
