Old Aug 6, 2024 | 03:16 PM
pizzaguy
Default Re: ~ Opinions on Altenator Diode Test Readings Requested Please ~
Originally Posted by Heli-Cal Blue
There is no parasitic drain or overloading draw/short circuits - that test reads at .24 .
SPec is nothing more than .055 amp, if you are seeing .24 amp, you have a huge problem. TO BE CLEAR, this is a current reading with the meter in series with the battery ground lead, on the 10amp scale-is that correct?
