Thread: Hello
Old Aug 12, 2024 | 08:50 PM
M60A3Driver
Default Re: Hello
Originally Posted by kerrycrossfire
Hello, I purchased my first 2004 crossfire the other day. On the drive home it sprung a leak in the fuel line....fun, fun, fun. 115 in the shade and I wasn't in the shade. Of course no way to get the part quickly and I didn't want to tow it, so I removed the part and took it to a parts store and had to buy a metal tubing fuel line part, cut it down, then cut the bad part from the leaking fuel line, slide the metal tubing in place and crimp it down on both ends. That worked.
Since then I ordered the part and am buying a few tools and tire fix.
Just saying hello and sharing my first experience but I also want to ask:
Can a standard oil change, tranny flush place be trusted to do my first fluid changes? I've never used dealerships.
Welcome to the forum!
These cars require certain types of fluids.
The most recommended engine oil filter is Mann HU 718/5x fleece oil filter.
The manufacturer recommended engine oil is Mobil 1 European Car Formula 0W-40.
Transmission oil depends on weather it's a manual or an automatic. These can be found by using the search bar in the right corner.
It's not hard to these, but if you're going to have it done for you have an independent European shop do it as previously stated.
Good luck!
