Old Aug 22, 2024 | 06:30 PM
pizzaguy
Default Re: Kenwood Radio Install
Originally Posted by modernuser
Will this allow me to control both the front and rear speakers? The custom one? Is there anything specific I should tell them over the phone to make sure I get the right thing? Last time they sent me that adapter I mentioned in my previous comment. Thank you so much! Looking forward to hearing that from you!!!!
NO NO
A THOUSAND TIMES, NO.
WHen your run the fader to the rear, you will get no sound. Stop expecting the system to do what it was not designed to do. The crossfire was built with a TWO CHANNEL AM/FM head, it had no fader. It has a left and right output, PERIOD. The amp in the car has four channels: Left Front, Right Front, Left Rear, Right Rear.
The car came wired like this:
AM/FM head Left output goes to amp's Left Front Input and Left Rear input.
AM/FM head Right output goes to amp's Right Front Input and Right Rear Input.
What must be done is four new wires must be ran from your new AM/FM head, these go to the amp. The EXISTING wiring is your FRONT speakers. The added wires are: Two for Left Rear and two for Right Rear.
THEN, at the amp, you connect the four new wires to the Left Rear and Right Rear inputs and cut the jumpers between Left front and Left Rear as well as the jumpers between Right Front and Right Rear. Your fader cant' work until you modify the wiring for true four channel sound.
It's all in this thread here:
https://www.crossfireforum.org/forum...-channels.html
M60A said: If you call Crutchfield and tell them exactly what car you have, they can make a plug and play adapter for you for about $24.00.
Perhaps, but what they do is to tie the left front and left rear together and the right front and right rear together. That kinda works, but yuk.
