Old Aug 31, 2024 | 12:32 AM
M60A3Driver
Default Re: Crossfire issues
Originally Posted by Too many cars
D.J. responded and I sent off original RCM for repair. I replaced the passenger front tire, so I can now safely test the car and actually drive it. Tire was worn to very little tread, but the real problem was the cracked sidewall on inside of tire. PO was driving it like that! But, I still have a BAS light on. At first it would go out by doing the reset, but only temporarily. Now it will not go out with the reset. The wheels needed cleaned and paint touched up, so while doing that I cleaned all the wheel sensors, to no avail. They looked pretty clean anyway. Drove the car, BAS on and the other symptom is the spoiler will not actuate at speed, nor will it retract when slowing. It does work fine with the dash button. No flashing light on spoiler button. It looks like my traction control switch does not actuate the dash light , no matter which way I move the switch?? Making progress, but this car is more neglected than the free one we were given 4 years ago. Of course it has less mileage as well. Any help would be appreciated. Oh, is the left front wheel speed sensor different looking than the other three sensor heads? It looks to me it has a magnet on it?
If the rebuilt RCM doesn't solve these problems you should scan the car for codes. You can take it to any major autoparts place. They should scan it as a Mercedes SLK 320 if it doesn't read as a Crossfire.
