Old Sep 3, 2024 | 12:27 AM
M60A3Driver
Default Re: KYB shocks front
Originally Posted by woo78n86
Hello, thanks for the information, I really didn't know I had to put in a category, but it makes sense. So, I went ahead and put KYB back on it. But the new ones have 280 lbs. of pressure in them. I'm just not that strong to collapse them. So, I'm going to check with my tire dealer and see if they will put them on, So when I post a question, I'm supposed to use daily threads.
The way I did mine was I pulled the shipping strap to the side and put the first rubber grommet on. Then I compressed the shock and put the shipping strap on. I bolted in the bottom mount first. Then I cut the strap and guided the shock into the hole.
The problem with doing that with yours is the pressure as you mentioned.
You don't have to put it in a category, but you will get faster and more replies that way.
Best of luck to you
