Old Sep 12, 2024 | 07:46 AM
dedwards0323
Default Re: Valve Cover Fastener Torque
Originally Posted by CROSSEDfingers4luck
7lbs torque on top breather box bolts, both the 2 long and 2 shorter single use machine thread bolts.
I hope i read this correctly
I don't believe you fully understood the previous post. The torque values for the 2 different screw sizes are different. The M5 screws that only hold the breather covers to the valve covers are torqued to 4 ft-lbs +/- 0.5 ft-lbs. The valve cover screws are torqued to 7.0 - 7.4 ft-lbs, including the ones that pass thru the crankcase breather covers.
Look over the attached file for clarification.
