Valve Cover Fastener Torque
Old Nov 13, 2023 | 06:32 PM
BarbarianCBX's Avatar
Default Valve Cover Fastener Torque
Sustained an oil leak from passenger side valve cover. Bought new elastomer Gaskets and bolts from Needswings.
1. What are the torque values for the two different length fasteners?
2. Is it necessary to replace the Gaskets on top covers if they are not leaking?
3. Is there a torque sequence ( tightening sequence and torque increments)?
TIA
Old Nov 13, 2023 | 08:05 PM
Default Re: Valve Cover Fastener Torque
TIA
1) Small Screws: 5-6 N-m; Large Screws: 10 N-m (Small Aluminum screws are not to be re-used - they are 1x use only)
2) I would replace the RTV on the Crankcase Breather Covers.
3) There is a recommended sequence on the valve cover screws, but I'd have to get the Service Manual out to find it. There is a thread on the forum that covers this repair. Worth a google!
Old Nov 14, 2023 | 11:41 AM
I would NEVER change the valve cover gaskets without also re-doing the RTV. To redo the RTV, read this:
https://www.crossfireforum.org/forum...over-leak.html
If that is too much to read, don't worry about it, just do the valve cover gaskets - you can do the whole job all over again if the breathers ever leak - which they will, in about a year.
Old Nov 14, 2023 | 04:40 PM
Thank you. I'll also RTV the covers.
Old Nov 14, 2023 | 05:09 PM
TIA
The two different length screw’s you are talking about I believe are the ones for the valve cover, these should have the same torque on them. The short aluminum screws are torqued to a different setting. They say they should only be used once. Some people are replacing them with stainless steel screws, I would not do that myself but each to their own.
Aluminum and stainless steel are at opposite ends of the galvanic scale so will attack one another strongly in a moist atmosphere, like sea air especially.
I already have my aluminum screws ready on the shelf just in case I need them. 🤞
You should download the Service Manual from the ‘TSB and How To ‘ forum on this site, it has all your answers in it. It is in the ‘Documentation’ sticky.
Old Nov 14, 2023 | 06:43 PM
I forgot about this with the larger screws. Thanks for catching this.
....The short aluminum screws are torqued to a different setting. They say they should only be used once. Some people are replacing them with stainless steel screws, I would not do that myself but each to their own.
I already have my aluminum screws ready on the shelf just in case I need them. 🤞 Ditto that!
I would agree with your feedback above. That's why I used alloy steel screws with a corrosion resistant protective covering. Similar to those used in marine applications.
'Metric Socket Head Cap Screws - Corrosion Resistant; Type: Metric Socket Head Cap Screws; Thread Size: M5x0.8; Length Under Head: 16.0000 mm; Material: Alloy Steel; Key Size: 4.000 mm; Finish/Coating: Blue Polymer.'
Old Nov 14, 2023 | 06:56 PM
I've searched and cannot find the torque pattern. For pipe flanges, I used across and one over, repetitively Thoughts?
Old Nov 15, 2023 | 08:07 AM
Probably is okay. Like you, I would start in the middle & Criss-Cross my way to the outside. Since the tightening torque is only 10 N-m, I didn't do a 2-step tightening process. I just applied the 10 N-m to each screw. But I did go back & re-apply the tightening torque a 2nd time since some screws could loosen a little as adjacent screws are tightened during the 1st pass. (Note: I do this also when tightening lug bolts or lug nuts on wheels.) Below is the torque sequence for the Cylinder head (for reference).
Old Nov 17, 2023 | 07:05 PM
Thanks all. Much appreciated.
Old Nov 19, 2023 | 11:41 PM
Agreed, here is the torque settings for the aluminum ones, also applies to the Stainless steel of course.
Old Sep 12, 2024 | 05:23 AM
CROSSEDfingers4luck's Avatar
7lbs torque on top breather box bolts, both the 2 long and 2 shorter single use machine thread bolts.
I hope i read this correctly
Old Sep 12, 2024 | 07:46 AM
I don't believe you fully understood the previous post. The torque values for the 2 different screw sizes are different. The M5 screws that only hold the breather covers to the valve covers are torqued to 4 ft-lbs +/- 0.5 ft-lbs. The valve cover screws are torqued to 7.0 - 7.4 ft-lbs, including the ones that pass thru the crankcase breather covers.
Look over the attached file for clarification.
Old Sep 12, 2024 | 11:21 AM
UrbanE's Avatar
If you’re going to do this, contact Rob at Needswings for new bolts. You never want to reuse the old ones.
Old Sep 19, 2024 | 08:13 AM
This is a required step when performing maintenance on leaking crankcase breather covers. The factory screws are an aluminum alloy and attempting to re-use these screws ends up just 'stretching' the screws which means the RTV seal will fail. The larger screws that hold the valve covers on do not need to be replaced (IMO).
I also recommend checking the valve cover screw torque setting as a routine maintenance task every year or 2. I have found these loose during a re-check in the past. And by doing this, I haven't had any leakage from the valve cover gaskets so far.
Old Sep 21, 2024 | 12:54 AM
I very much appreciate your knowledge and experience not to mention taking the time to assist with my endeavor. I considered all your suggestions and the covers were installed per spec as you all had suggested with both sides receiving new aluminum bolts. You all are much appreciated
2004_
May 22, 2016 08:16 AM
BisB
24
Mar 14, 2016 10:44 AM
specialized1953
24
Feb 4, 2016 02:05 PM
meh03
Feb 2, 2013 08:06 AM
ri2300
Jan 17, 2011 09:34 PM
