Thread: Headlight issue
Old Sep 12, 2024 | 09:18 PM
M60A3Driver
Default Re: Headlight issue
Originally Posted by BeehappyjamAdaMay2020$
New crossfire owner, I was installing new H7 bulbs, on passenger side the plastic connector crumbled and the wire connectors touched. Now the low beam works but not high beam on that side. High works on the other side. Hindsight I should have disconnected the battery before monkeying around with the lights.
Are you talking about the plastic connector with the wires in it that hooks onto the prongs of the bulb?
If so you might be able to get one off of e bay and splice it, or you might be able to push the wires out and push your wires into the new one.
