Headlight issue
Old Sep 12, 2024 | 04:44 PM
BeehappyjamAdaMay2020$'s Avatar
Default Headlight issue
New crossfire owner, I was installing new H7 bulbs, on passenger side the plastic connector crumbled and the wire connectors touched. Now the low beam works but not high beam on that side. High works on the other side. Hindsight I should have disconnected the battery before monkeying around with the lights.
Old Sep 12, 2024 | 09:18 PM
Default Re: Headlight issue
Are you talking about the plastic connector with the wires in it that hooks onto the prongs of the bulb?
If so you might be able to get one off of e bay and splice it, or you might be able to push the wires out and push your wires into the new one.
Old Sep 12, 2024 | 10:26 PM
Yes the plastic plug crumbled. I put the wire connectors directly onto the bulb. Btw this happened to the low beam bulb which works fine but high beam on that side no longer works.
Also the left turn signal no longer works. I removed the high beam bulb and tried turning it on, it does burn very dimmly
Last edited by BeehappyjamAdaMay2020$; Sep 13, 2024 at 05:20 AM. Reason: Adding to
Old Sep 13, 2024 | 11:15 AM
Try replacing the front and rear turn signal bulbs and see if that fixes it. Also make sure you didn't blow any fuses.
For the high beam, clean the where the bulb contacts the socket and the metal part of the bulb itself. It may be a bad ground that's making it go dim. You can use contact cleaner, or spray a little brake cleaner on a rag and wipe both surfaces.
Old Oct 9, 2024 | 10:55 AM
I finally figured out the problem. On the main connector for driver side headlight the ground in had got bent snd was barely making connection. Whalah all lights function properly
Old Oct 10, 2024 | 12:02 PM
Thanks for the update. I'm glad you fixed it!
Deepsea21
Feb 9, 2022 11:56 PM
Steve - UK
Nov 27, 2015 12:07 AM
Joliet John
Aug 7, 2010 12:40 PM
Archie70
Sep 2, 2008 09:16 PM
