Old Sep 18, 2024 | 12:28 AM
M60A3Driver
Default Re: Cylinders #4 & #5 misfire code
Originally Posted by Romad
When it acted up, and going back to idle, it still stayed the same rough engine malfunction and I was afraid I'd be left stranded. Has 110K miles and don't know if it has ever had a fuel filter change. Maybe I could do that but want it to fail first!
Changing the wires, plugs and coils should help no matter what.
It may be a fuel filter starting to clog. I had that on an old Ramcharger. It would drive fine for about 20 minutes, then I would have to pull over and let everything settle. then it would run fine again.
The difference being the truck had a sock style filter and our cars have a canister filter.
You could try to run some Sea Foam through the gas or have the injectors cleaned.
