Old Sep 18, 2024 | 09:17 PM
M60A3Driver
Default Re: No speedometer, no brake lights, all dash indicator lights on
Originally Posted by Teamstockle
Just bought my first Crossfire. Everything was great for about 2 hrs. Now it still runs fine but speedometer and brake lights not working and all the dash warning lights are on. I cleaned up all grounds. I looked at the rcm at the solder joints look ok and all relays appear good. No dark or burnt contacts. Should I order a new rcm? Thanks for any insight.
Try this, disconnect the negative lead from the battery and let it sit for a few minutes. If you have a voltage tester check the battery voltage.
If the battery is old or the voltage is low, it will cause all kinds of weird things to happen.
Reconnect the negative cable and see if the trouble is still there. If it is, it could be the RCM. Even though it looks good it may not be.
Grab a spare off of amazon and send your original out to @tighed1
