Old Sep 18, 2024 | 09:24 PM
M60A3Driver
Default Re: Car dash lights up like a Christmas 🎄
Originally Posted by Bzak1pgh
Driving my 05 Chrysler Crossfire base and my dash lights up with every light then goes into limp mode. Pulled over, engine hot as hell, and temp guage shows cold. Replaced thermostat 2 months ago for the same issue thinking that was the problem. Fan kicks on so it's not the fan. I did get a P0900 code...best I can remember with a generic ob2 scanne, but i think it was due to batterywas almost dead. Recharged battery to full afterwards. Any help would be greatly appreciated!!!
Have you checked your coolant level? Also if your gauge isn't reading hot, maybe you have a bad sensor.
Also check your water pump and see if it's seeping coolant. With the engine off, loosen the belt and spin the pump pulley by hand and see if it's turning freely.
Maybe the RCM is bad as well?
