Old Sep 25, 2024 | 11:57 PM
M60A3Driver
Default Re: Center support with bearing 2004 crossfire
Originally Posted by HappyHippy
2004 Crossfire...After reading many different posts. I'm pleased to share that I was able to buy the center support / bearing thru Amazon. Took car to a local mechanic and expressed that I watched several videos on this site of how it can be replaced without having to buy a new driveshaft, with only needing to detach and move heat shield forward to remove driveshaft.
They had it done in about an hour and a half at the cost of $135. The support w/bearing thru Amazon was $60. Total about $200.
Did you have them replace the flex discs while they were there?
