Old Oct 17, 2024 | 02:37 PM
Nelson G's Avatar
Nelson G
Default Re: Maintenance indicator
It indicates that the car is 9300 miles past its service. When you look in the manual it will have what is indicated to be serviced. Considering you just purchased the car I would say do a full service. When I purchased my car back in December I went through the car. I changed the trans fluid, filter, and gasket, then I bled the brakes and changed the fluid, and the brake hoses due to the age of the car, rear end fluid change, air filters changed, cleaned the area under the front cowl, interior air filter, changed the belts and some of the pullies, sticky key was done, CPS was changed, RCM was sent out to be repaired and a new one was purchased.
This is a good place to start: https://www.crossfireforum.org/forum/585345-post1.html
