Old Oct 19, 2024 | 02:22 AM
M60A3Driver
Default Re: No crank no start issue
Originally Posted by Brendan.l
Hello everyone,
I'm currently struggling with my crossfire, I have a
2004 Chrysler Crossfire that ran very well with no issues whatsoever so ever. After leaving for a field training for the army for 3 weeks I returned to the car doing the classic SKREEM issue. I sent it into the Mercedes swap shop where he fixed the code and sent it back. The car still didn't start after install. I then replaced the battery, and it started right up, drive down the road and it turned off at a red light. I towed it back and re evaluated because now it was cranking but not starting and the battery died after a few attempts. I then swapped the crank shaft position sensor, re-soldered the RCM and I put in a brand new alternator. It started up again and then did a no crank no start when attempting to leave work the following day. I attempted it a few days later and it started up with a slight stutter. I was able to drive it 10 miles home. Now it it sitting no crank no start. I have no clue what else to do to it to get it running again. I am in serious need of this vehicle as my job requires that I have a reliable working car. I'm trying to fix it so I can get rid of it already. Please HELP if you have any suggestions!!!
I think your best bet would be to call the MSS again and explain what is happening now that you have installed everything. I've heard they are good people and they might be able to help you solve the problem over the phone.
