Old Oct 19, 2024 | 04:16 PM
Nelson G's Avatar
Nelson G
Default Re: Transmission Bulkhead connector
The fluid breaks down, so it is cheap enough to change it. And the plug is easy to replace. You will need a trans dipstick so you can make sure you have the right amount. I did mine, the only problem was the plug did not fit as well, so I purchased another one and the leak went away.
