Old Oct 26, 2024 | 01:12 AM
M60A3Driver
Default Re: Battery Drain and Strange noise coming from BCM Area
Originally Posted by robdoy
Thanks, what a great write up, the details make such a difference. Removed the siren and no more noise, amps dropped down to 0.16, looks like I still have a issue on fuse #9. The search will continue. Thanks again
I'm glad that you found it useful.
For the fuse 9 issue; do you have leds in the dome light? Try shutting the dome light switch to off, or remove both bulbs. Be careful, the plastic on the lens is brittle.
