Old Oct 26, 2024 | 01:47 AM
M60A3Driver
Default Re: Convertible top issue-
Originally Posted by jeadlbombers
Your re-enactment is spot on. Thank you for understanding it all. So after a new top, 2 new hydraulic lift arms, I have no functional top. But at least the windows go down when the D handle is activated.
No problem.
Like ZERACER and GraphiteGhost posted, maybe it's the cylinder position sensors.
You can also try looking at the trunk divider switch. It's located on the left side in the U shaped slot that the trunk panel hooks into. Make sure that it moves correctly. You can bypass it and see if your top works. Apparently this switch fails a lot.
This thread by pizzaguy has a ton of information in it. Conertible top thread
