Convertible top issue-
Old Nov 5, 2024 | 08:55 AM
jeadlbombers's Avatar
Default Re: Convertible top issue-
I tried them
also, and they said no
Old Nov 5, 2024 | 09:45 AM
Have you read post 17 for the top? For mechanical issues you can't do on your own, go to an independent shop that does Mercedes and tell them it is the same as a 2003 Mercedes SLK 320.
Old Nov 6, 2024 | 01:20 AM
Originally Posted by jeadlbombers
I tried them
Here is a list of independent Mercedes shops in your area
CLICK HERE Benz shops
Old Dec 10, 2024 | 05:04 PM
nickwe21's Avatar
I would
1) Watch the Top Hydraulic video series on Youtube. Your problem can most likely be fixed yourself once you invest a little bit of time into making yourself familiar with the basics (hydraulic cylinders, sensors that attach, the relay/control module, the pump etc)
2) Start with the simple things such as making sure the top cylinder sensors were attached correctly
3) If you want to take your car to a repair shop, take it to ANY European aftermarket repair shop that works on Mercedes. They will figure this out rather quickly. Taking it to Chrysler is a nightmare waiting to happen.
4) I would insist that the folks who gave you back a messed up car fix the problem. That is really where I would start if you do not want to work on it yourself. Klaus, the owner of Top Hydraulics, will assist them in fixing whatever is going on, if they gave him a call.
Old Dec 10, 2024 | 08:13 PM
Originally Posted by nickwe21
I would
thank you for your response. Truly appreciate you. I found a foreign car shop here in Midlothian that’s gonna take a look at it. Hopefully he can figure it out. I’ll probably give him Top Hydrolics number so they can walk through the process. The company called Interior Guys worked on it originally and couldn’t fix it. They were able to get the windows to do down when you release the D handle bit that’s it, thanks again for your help
Buzz
May 8, 2024 03:36 PM
My Baby
Nov 4, 2021 03:02 PM
jayrx7trbo2
Oct 10, 2018 11:06 AM
JAdams805
Mar 12, 2015 06:21 PM
