M60A3Driver
It could be a bad relay control module, (RCM).
More information would be helpful.
Year? N/A or SRT6? Mileage? Does it make any noise when you try to start it? etc...
initially, the car stalled after driving about five minutes and restored it after it about 20 minutes. It is a 2006 Chrysler crossfire limited coupe with around 80,000 miles. I bought the car. I replaced the transmission position position sensor. For about 30 minutes and then died. tried to hook up a code scanner, but it would not read the ECU when the key is inserted. There is no fuel pump sound, the rear wing will go up and the fan starts racing at a high speed. All the dash lights are on the battery and it is fully charged. There is no sound when you turn the key. It doesn’t click nothing disconnect the battery cables and hook them together and reinstalled. The car crank for about two seconds and ran and then died. I did that again same result ran two seconds and died.
