Old Oct 27, 2024 | 12:50 AM
M60A3Driver
Default Re: Battery Drain and Strange noise coming from BCM Area
Originally Posted by robdoy
Hello again, as I was testing the amperage, I would wait for about a minute each time when the ready steady out and go with that reading. So I decided to clamp the multimeter probes to the battery post and clamp and start pulling fuses again. I got distracted for a few minutes and when I looked over, the reading had dropped to 0.01 and stayed there. So I tried it many times again and It took approx 1.75 minutes for the draw to drop down from 0.160 to 0.01, and then it stays there. Would this be normal and the siren was my only problem. Everything now is steady at 0.01 Ma. Thanks for your thoughts on this matter.
Another known draw on the battery is the stock radio. Do you still have the original radio?
If so, try pulling the fuses related to the radio and see if that draw goes away.
Pizzaguy has an excellent post on how to find a battery draw. It's in the troubleshooting section.
