M60A3Driver
I would guess the RCM is bad. The RCM has a group of relays in it, one of them being the fuel pump.
You can get one off of amazon. You can replace it and see if it solves your problems. If it does, I would send your original out to
@tighed1 and have it repaired. It is recommended to carry a spare RCM because they are known to fail.
Here's a link to the one on amazon:
Amazon RCM
You should also carry a spare Crank Position Sensor (Use BOSCH only).
thank you so much for taking the time to help me out. I am going to pull the RCM and have it repaired. Also, do you have any suggestions for a code reader that will work on a crossfire. My budget is about $250 or less.
