Old Nov 11, 2024 | 10:24 AM
pizzaguy
Default Re: Spoiler not operating
Originally Posted by Zen Beer
I think it might be a limit switch as it shows both extended and retracted as active in the io display menu.
Use a voltmeter at the connector on the BCM, If both are high, the wing is between "UP" and "DOWN" or if it is UP or DOWN, then that limit switch is bad.
If both are low, I'd suspect a loss of bias from the BCM, altho it could be that both wires are shorted to ground somewhere, altho I doubt that.
Of course, once in a while, it's the MOTOR that has simply failed. Measuring for power going to the motor when the button is pressed will reveal that.
