Old Nov 26, 2024 | 06:08 PM
mikemadeit94's Avatar
mikemadeit94
Default Re: SKEEM Issues (After Re-Flash)
Originally Posted by ZERACER
Low voltage can also damage your screem. I would start there. Also, it is recommended to always disconnect the negative first and re-attach it last.
Just got the battery back, fully charged no bad cells it's only a few months old. Same symptoms I disconnected the antenna ring and ohm tested between the two terminals and got no reading seems to be bad. Going to try to pull one from junkyard or order another. Hopefully this is the issue!
