Old Dec 1, 2024 | 09:37 PM
amx1397
Default Re: Removing interior panels for backup camera installation question
If u go from the pass side of dash ,, under the carpet.....remove the doe sells(plate,,, under the carpet to the back and in front of the gas tank next to the hump in the back you can send wires up to 1/2 " through the hole ,,, go along the carpet at the top,,, then remove the carpet on the inside of the trunk,,,,,,you will ess a hole in the trunk at the tag light ,,,go through there ,,,,cut a small V in the top of your license plate ,(not too big ,you want your plate cover to cover the V cut ,,,,,,,,,,done
No cutting ,,no drilling just slide the wires through 15 min your done. JIM
