Old Dec 10, 2024 | 07:04 PM
mikemadeit94's Avatar
mikemadeit94
Default Re: SKEEM Issues (After Re-Flash)
Originally Posted by red_2005_convertible
Hi Mike,
when you say 3 cranks and then nothing - does the car start for like 10 seconds in between the 3 tries, or does the engine only turn over 3 times and never starts? What's your battery voltage as you try to start the car? Does it go very low after 3 cranks? (Just grasping for straws since it looks like the SKREEM isn't the issue.)
-Jerry
I'm going to do a deep dive once my skreem gets back in the next day or two, its hard to remember I think it was sporadic if I remember right the car would just start sputter out in about two seconds 3 cranks then nothing. (Same thing happened when I forgot to put my little chip back in when I recased also why I believed it to be the skreem module. MSS confirmed though the sckreem did need a reflash when it hit his bench. I'll have to double check on that battery voltage I brought it to orileys they charged and tested it said all cells where good and it charged to full its not very old either think 3 or 4 months.
