Old Dec 20, 2024 | 07:54 PM
M60A3Driver
Default Re: LED bulb for map lights with a socket base
Originally Posted by rctitus
I sourced a product from Amazon (China) that does not have correct twist-lock dimension - its slot is too skinny to fit the carrier base plastic, so it isn't able to twist into lock position.
Anyone have a source that actually fits our Crossfire (2007). I've been lucky so far with the festoon-style glove box and trunk lights.
Any help is appreciated!
I assume this is for the interior dome lights? Is your socket broken? You can replace the bulb itself and re-use the socket.
If you're trying to replace with LEDs, I would stick with the original bulbs. I replaced mine with Leds and they never shut off. They go real dim, but I have to turn the switch off or they will stay lit.
