Old Dec 27, 2024 | 10:31 PM
M60A3Driver
Default Re: LED bulb for map lights with a socket base
Originally Posted by Nelson G
I use the existing socket. I had to remove the overhead light assembly to get access to the bulb as you can see the diffusers are still there. The bulbs just slip right into the socket.
I tried the Lasfit L-T10R bulbs, unfortunately they wouldn't fit into the original blues sockets. I have a 2006, maybe it's different than yours?
There are "fins" inside the bulb socket that prevent the center part from moving. Also the Lasfits were to thick to fit in the slots of my car's bulb sockets. I'll use them in the future for something else.
I ended up adding a piece of copper inside on each tab, so that they would make contact with another T-10 type LED. It works great and they fade like the regulars and go all the way off.
Thanks anyways, I appreciate the help.
