Thread: Hesitant start
Old Feb 5, 2025 | 11:33 AM
pizzaguy
Default Re: Hesitant start
Originally Posted by ajchicago
this is a quick clip for how it (was) starting
Generally speaking, anyone who replaces the starter on a care with an M112 engine finds out it fixed nothing. I've been on this forum 16 years as of July 10,2025. I know of two starters that were bad, all the rest was RCM/Battery/etc.
In your case, given how it first spins very slowly then speed up, I don't THINK it's the battery after all. I tend to agree, you may have (as rare as it is) a bad starter. An analog voltmeter would tell you what is going on, if you could measure the voltage at the OUTPUT of the solenoid during cranking, if that voltage starts off low then climbs, I'd suspect the battery or solenoid. If not, I'd suspect the starter.
I RARELY say this, but I think replacing your starter and solenoid would be a good guess if the battery is new. With Crossfires, my default is to replace the battery first in any case like this:
Won't crank.
Cranks slowly
Wing has a mind of it's own
Convertible top acts erratically when putting top up or down without engine running (Of course, putting top up or down without the engine running is what fools do...)
Lots of yellow lights on instrument panel (BAS/EAS, etc.)
....... most any other weird electrically-related complaint.
