Old Feb 22, 2025 | 02:33 AM
M60A3Driver
Default Re: Front Fender Bolt Measurement
Originally Posted by Bandit55
Hello,
I'm working on a 2004 coupe with minor front end damage. I have all of the bent parts removed (Core Support only) but I'm having a problem with fender gap alignment. I'm not sure what is causing the problem ... so can someone please measure the distance between the center of the bolt head on the right and left fender bolts, just the 3rd and 4th bolts securing the fender to the body?
Thank you
Brian
I have a 2006 roadster. When I go out to the garage tomorrow I'll measure the distance. It should be the same.
