Old Mar 5, 2025 | 07:46 PM
dedwards0323
Default Re: Windshield washer fluid tank is leaky...?
Originally Posted by Valk
Washer fluid will spill out the side before it will fill to the top
It can hold about 1 gallon and if you try to keep filling it at some point it will begin to spill in on the ground as you experienced
Most likely it's not a leak !!
I always suspected this. Fluid always leaks out whenever I filled it up. Most likely because I fill it up before the low level alarm comes on. I'm guessing that when the low level alarm comes on the IP, you can add 1 liter of fluid w/o spilling any. Duh!
