Old Mar 18, 2025 | 02:22 AM
  #8624 (permalink)
GraphiteGhost
Originally Posted by Esinclair
The filters are in the housings, not out in front of the radiator.
The left filter has a tube about 3/4" in diameter that connects to the top of the valve cover. PCV I'm assuming. No PCV valve. No other air can enter the filter housings except for the ~5" tubes that extend from each filter housing into the area beside the radiator on each side.
I'm waiting on a reply from the filter manufacturer for a cross reference as to the application of the charcoal filter that everyone keeps calling a cabin air filter.
I hope this answers your questions. Thank you for input.
In the photo below, you can see that I have pulled the right side air intake tube off of the filter housing. Normally it is connected.
Thank you for explaining the setup in that airbox. Looking up the filters for that airbox should be all you need. Since it (that so called CAF filter in that bracket) is above the hose leading to the airbox and is the filter for the PCV? Good luck, and thanks again for the reply.
