GraphiteGhost
Thank you for explaining the setup in that airbox. Looking up the filters for that airbox should be all you need. Since it (that so called CAF filter in that bracket) is above the hose leading to the airbox and is the filter for the PCV? Good luck, and thanks again for the reply.
Thank you for your reply.
My guess was that it is the PCV filter to slow fouling the regular paper filter. I will reinstall it.
EDIT: THE PAPER FILTER IS "IN FRONT" OF THE CHARCOAL. THE CHARCOAL FILTER DOESN'T STOP THE CRANKCASE VENT FUMES FROM HITTING THE PAPER FILTER. I DID NOT REINSTALL IT.
I sent a message to the manufacturer, "Mann", here is their reply:[After further discussion and research it was determined that AE 2501 is made for a private original equipment manufacturer.
It is not sold in the aftermarket and no other information is available on the product.
[color=black]Thank you,
Mann+Hummel Product Information
Product Information (800) 526-4250)
MANN+HUMMEL Filtration Technology, 1 Wix Way, Gastonia, NC, USA]
