Old Mar 21, 2025 | 12:02 AM
GraphiteGhost
Default Re: Climate control blowing warm air.
Originally Posted by xintersecty
@M60A3Driver wrote an excellent post on removing the climate control module..
https://www.crossfireforum.org/forum...tml#post996771
After examining his post and some of the above answers, I have some more qualification questions:
1) Does the fan speed dial change any of the position of the white mechanical linkages at the back of the unit.
2) The two slider ***** for passenger and driver temperatures, must have a potentiometer. Do they go bad causing the temperature to fluctuate?
I can see how the potentiometer in the fan **** can go bad and cause erratic fan speed changes.
Personally I believe the white linkages go to a vacuum valve(s?) to control the various dampers for moving air to different positions. See red arrow.
1. Fan speed dial does not move the two shafts. 2. Have no idea if the temp ***** have ever been a problem going bad. Finally, the two shafts key into matching socket shafts coming out of the plenum of the heat/ac box, the inside of the plenum has ductwork vanes that direct air according to the dial icons in the Heat/AC head. Good luck!
