Old Mar 28, 2025 | 06:07 PM
DTMenace's Avatar
DTMenace
Default Re: 2005 water pump with a flat gasket
Originally Posted by Jdabs
Hi, I as well have a 2005 crossfire 6 speed manual,m not srt. I’m replacing my water pump now as we speak. I took off my water pump and there is a flat metal “gasket” between the pump and the block. The new one I bought comes with a PAPER flat gasket. Do I use that?! In the instructions it says to apply sealant to it. 1. should I use the paper gasket? 2. If yes what type of sealant do I use? 3. Do I apply sealant to both sides of the gasket?
Jdabs
Do not use a paper gasket, order one from NeedsWings.com and specify that your Crossfire is a Limited Model, since the SRT6's water pump is different.
Good Luck....
Dennis
DTMenace
