Thread: Fast flashers
Old Apr 9, 2025 | 10:24 AM
M60A3Driver
Default Re: Fast flashers
Originally Posted by bluey42
My Crossfire failed registration (in Australia) as the indicators are flashing too fast.
I know that this topic has been discussed before but I didn't see reference to this particular issue on any of the threads.
The engine fuse box has two large relays (about 1" cube) at the rear and the black one is meant to be the flasher relay.
I removed this relay (part no 002 542 21 19) which is referred to as a Mercedes Turn Signal Relay and checked the resistance
which seems to be normal, about 90 ohm, indicating no fault in the relay.
The weird issue is that the indicators are still flashing (fast) with both relays removed - I can't understand that.
As the car is presently unregistered and off the road, I would appreciate experienced advice egarding this problem.
Thanks all
Ron
Have you checked that all of the bulbs are working? Are they LEDs?
Also the inside of the turn signal switch may be dirty. With the car off, you can spray a little bit of contact cleaner into the switch. Move the stalk a bit while spraying.
Let it dry after spraying, then try it.
Maybe that will help.
