Fast flashers
Old Jun 29, 2025 | 12:48 PM
Deepsea21's Avatar
Default Re: Fast flashers
I fought the bad contact issue myself on one of my front turn signal sockets. The contacts on that socket that holds the bulb can get co pressed over time and lose contact with the points inside the light that are to make contact when you twist it in place. I tried prying the contacts out a bit but that was too much to get it to turn into place so I pressed them back in a bit and that was too far to make contact. I ended up snipping the tips off a couple toothpicks and slid them under those contact points on the bulb plug. Twisted it into place and still working. A more permanent fix would be to put a glob of solder on them but have to be careful not to add too much or you won’t be able to turn the socket into place.
Old Jun 29, 2025 | 04:57 PM
PhilH's Avatar
Thanks for the tip. I finally sorted my problem but did so many things I don’t know which one actually fixed it
Old Jun 29, 2025 | 05:04 PM
Needswings has the replacements:
https://needswings.com/headlight-tur...al-bulb-socket
Peteroses1975
Oct 8, 2018 09:57 PM
waldig
Dec 11, 2017 11:25 PM
LarryDamm
Aug 16, 2017 10:44 PM
XF Tom
Aug 28, 2013 08:12 PM
Parallel Ice
May 17, 2013 09:18 PM
