It's not science until you write it down. Well I took pictures and going to write it down.
I got a fuel pressure tester from HF and run some tests last night based.
Running Pressure
60 PSI while running
Fuel Pressure with engine off:
Fuel Pressure after turning off 55 PSI
Fuel pressure after long wait ( GF and I were practicing **** dancing (not what you think it is) and it got dark). Estimated time about 45 mins to an hour.
About 45 min wait, pressure drop to 24 PSI
I get only one fault on the scanner with ODBII
P0453
P0453 Evaporative Emission Control System Pressure Sensor High Input
During Idle, the car will start to slow down and shutoff. The fuel pressure does not drop. I am not sure about the cause. I did replace this valve located here:
2005 CHRYSLER CROSSFIRE 3.2L V6 Exhaust & Emission : Vapor Canister Purge Valve / Solenoid
So I am stuck. I don't have enough engine codes to say what else to replace.
