bluey42
Thanks for the replies.
Flashers still going fast.
My comments are:
All bulbs are working, external and internal
The are no LED bulbs in the system- all bulbs are as per spec.
Indicators were flahing properly but became faster with time.
I cleaned all contact, no change.
Hazard switch is working properly.
Am I missing something obvious?
Strange... In the good ole days the flasher went fast when one lamp filament in the circuit was burned open (no light). These newer circuits are different as I understand it but I have no idea why yours is acting like a bulb is out (in the left/right turn signals). I would check (as a suggestion) the bulbs brightness at night when it is dark enough to see if one bulb in the circuit is much dimmer or much brighter. This might show up as a flashing faster symptom (again, it is just a suggestion to try). Good luck (I hope one bulb is brighter or dimmer than the others).
