Thread: Fast flashers
Old Apr 12, 2025 | 08:18 AM
xintersecty's Avatar
xintersecty
Default Re: Fast flashers
Originally Posted by UnderTheSouthernCross
Hi had a fast flashing right indicator.
I found that the contacts in the bulb holder (in the headlight assembly) had not been touching properly and were arcing. The arcing burned a hole int he contact on the bulb holder. I filled the hole with some solder and popped it back in. Good contact was re-established and indicator now behaves as normal.
Thanks for the follow up and solution. This is good historical data in case somebody else has this issue.
