Thread: Newbie owner
Old May 14, 2025 | 10:07 PM
M60A3Driver
Default Re: Newbie owner
Originally Posted by dwpost
Had these years ago guess I got sentimental
couple issues would appreciate some help
1) Occasionally the starter stays engaged when trying to start the car
when battery is disconnected and I’ve gone thru start cycle w key key seems to spring back from engage starter
position well. Anybody see this problem before?
2). alternatornsounds like it’s dying any particulat supplier better than another on replacement.?
3). 3rd brakelight half working found rebuild guy on this site saved 250 bucks. Thanks!
Thanks in advance
carbhas only 50k on it
Hi,
going by the numbers;
1) It sounds like the bendix drive on your starter is failing. (That's the solenoid that pushes the gear onto the fly wheel to make it turn and start the car).
You can find a good starter for a good price at Rockauto.com
2) You can have your alternator rebuilt at any automotive generator shop. If you decide to buy a new one, it is important to know if you have a Bosch or a Valeo.
A Bosch alternator has 2 connector posts on the back of it. A Valeo alternator has 1 connector post on the back.
3) When searching for parts on European based sites, like engine, transmission, suspension, etc... remember your car is basically a 2001- 2004 Mercedes- Benz SLK 320 or SLK 32 AMG if it's an SRT6.
4) you might also want to have your battery load tested to make sure that's not causing these symptoms.
Good luck with your car!
