Thread: Fast flashers
Old May 19, 2025 | 01:34 AM
M60A3Driver
Default Re: Fast flashers
Originally Posted by UnderTheSouthernCross
Hi! I had a fast flashing right indicator.
I found that the contacts in the bulb holder (in the headlight assembly) had not been touching properly and were arcing. The arcing burned a hole in the contact on the bulb holder. I filled the hole with some solder and popped it back in. Good contact was re-established and indicator now behaves as normal.
If it's not too much trouble, would you be able to post a picture showing the repair that you made? I would like to see where it was, just for future reference. No rush, whenever it's convenient for you.
Thanks in advance,
John
